[Marketing] Use URL Logger for your own Cloud based low code solution
2 years 3 months ago - 2 years 3 months ago #24076 by prashant
Problem Statement
Using Gravity Forms , when we upload files to them , all files are stored by default on company servers, let's say Firkee.com in our case. If we use Dropbox or Gdrive add-on for gravity forms  , Webhooks sadly are fired immediately and then processing to dropbox or Gdrive happen. This means , Webhooks will always have files from Firkee.com , and these links are deleted by Dropbox/Gdrive Addon
As of July 2024 , gravity forms refuses to solve this , the "hack" is to install php code for each webhook for each form for each field , it gets very messy very quickly.
Other Solutions
  • Use Zapier / Make / n8n - All solutions cost money ,are step based , another SAAS in picture. A Bare minimum package from them is $25/month or more.
  • Hire Wordpress developers which can help you achieve this - The costs is already running in $300+
  • Sync mySQL table to local drive with a sync - Gravity forms syncs data across multiple tables , solution exists but it's tedious
Enter URL-Logger
  • URL logger is a node.js based solution by ETL-tools for only $100 , it's wicked fast and writes everything to a SQL / sqlite database of choice
  • All the gravity forms now send a webhook to URL-logger , say myserver.com/gdrive_upload
  • URL Logger has a facility to trigger scripts , whenever data hits , these scripts can run async or detached without waiting for script to finish.
  • We use a simple python script , made by ChatGPT which reads the
    • json from MS-SQL,
    • find all links inside json ,
    • download the file ,
    • uploads the file to Gdrive,
    • Updates the Json file with gdrive link
    • Send the link to wherever you want
Thoughts
  • This is a very customised solution to a customised problem , but works great for us
  • This took us around 3 hours to figure , 2.5 hours went in breaking head with ChatGPT to write the script and test it.
  • Having URL Logger , with it's solid capability to receive webhbookos quickly, and customized end points , allows us to dream of a solution like this.
  • No need for another SAAS ! Obviously if you are accepting 50 webh-ooks per second, then we need a queueing mechanism and we must use Packages to solve this.
  • If we want logs, then we can use packages to achieve the same. Team ETL , let me know if we can use Cloud Storage package instead to upload files(but I have large accounts on gdrive  1TB+, that's my issue)
PS
  • Does it sound like a sales pitch ! It is , URL Logger is amazeballs
Last edit: 2 years 3 months ago by prashant.
