add fixed values in writer (output) without reader (input) side
3 years 5 months ago #22449 by nveger
Hi,
I have an source file (excel) that has 21 fields. I need to parse these values into a target file (also excel) that has 65 fileds. Some of the fields that are NOT in the source file, I want to populate with a fixed string in the target file.
How can I do this? The transformation from source to target is going well, but how can I "enrich" the target file with fixed values that aren't in the source?
Regards,
Norman
3 years 5 months ago #22450 by admin
Hi Norman.
Thank you for using our support forum.
You can use literal transformation for that
www.etl-tools.com/wiki/advanced-etl-proc...scellaneous/literal/
3 years 5 months ago #22451 by nveger
nevermind, I had to use Literal
