Not able to execute SQL script ORACLE
4 years 7 months ago #21541 by BPO
Hello,
I am using Visual Importer Enterprise V9.2.9.0 / 64bit
I want execute a SQL query on ORACLE DB but when trying to execute it I have following error (see capture2) of provider seems to be not found. I tested the same query on same DB connection it in the "Run SQL" tab and all work as expected (see capture3).
The connection to this ORACLE DB is working perfectly (see capture) and all other task of extract/load I am doing are working perfectly.
Thanks !
Benjamin
4 years 7 months ago #21542 by admin
Hi Benjamin.
We have reproduced the problem we hope to give you an update next week
4 years 6 months ago #21552 by BPO
Hi Mike,
Thx for the prompt feedback, looking forward to your update.
4 years 6 months ago #21563 by admin
Please try the latest version and let us know the outcome
The changes are
+ Added: Out parameters to reports
- Fixed: Issue with running Oracle SQL scripts from sql script screen
4 years 6 months ago #21565 by BPO
Mike I have updated and the query works well now, but I got an error when scheduling it.
(I have tested executing scheduled task with agent and vimpent, I get the same error for both).
See attached screenshot / I also forwarded vimpent error mail to you.
4 years 6 months ago #21566 by admin
Looking at it now
