Need help creating side-by-side columns (Kanban style)
10 months 3 weeks ago - 10 months 3 weeks ago #25880 by Onkar2002
 I am trying to create a specific layout in FastReport and hitting a wall. I need a "Dashboard" style report for employee tasks.The Goal:
Page Layout: Standard portrait page (0 columns).
Top: Employee Name & Photo (Full width).
Bottom: A list of tasks grouped by Frequency (Daily, Weekly, Monthly).The Requirement: I need the task groups to appear side-by-side in vertical columns (like a Kanban board).
Column 1: Daily Tasks
Column 2: Weekly Tasks (Must start at the top of Col 2)
Column 3: Monthly Tasks (Must start at the top of Col 3)What I have tried:
I set the MasterData band to 3 Columns.
I wrote a custom SQL sort so the data comes in strictly ordered: Daily -> Weekly -> Monthly.
I tried using StartNewPage = True on the GroupHeader, but this forces a completely new sheet of paper, not just a column break.
I tried using Engine.NewColumn in the OnBeforePrint script of the GroupHeader, but it doesn't seem to trigger the jump correctly inside the band.
The Problem: I cannot get the "Weekly" header to snap to the top of the next column. It either flows right underneath "Daily" (like a normal list) or breaks to a new page entirely.
My Question: How do I configure the GroupHeader + MasterData band so that when the Group changes (e.g., from Daily to Weekly), it forces a Column Break only, keeping everything on the same page?
this is how it looks right now
The following img is my expected output
and this the fast reports
I would be very grateful for any advice or script examples.
Last edit: 10 months 3 weeks ago by Onkar2002.
10 months 3 weeks ago - 10 months 3 weeks ago #25883 by admin
I am struggling to understand the issue to be honest.
We need an example from you.
Actual database and actual report pointing to this database.
You can use ms access as the database
Last edit: 10 months 3 weeks ago by admin.
10 months 3 weeks ago #25884 by Peter.Jonson
Perhaps the solution here is to use side by side subreports
The following user(s) said Thank You: Onkar2002
