URL Logger on SQL Express
2 years 6 months ago #23327 by prashant
Hellos,
I finally decided to give SQL Express 2019 a try as recommended . It's installed on default instance SQLEXPRESS, port 1433
But I URL Logger is unable to connect to it, I have tried with 1433 and without it
{     "RUN_SQL_SCRIPTS": 1,     "WEB_SERVER_PORT": 3333,     "ENVIRONMENT_NAME": "DEV",     "ENABLE_SECURITY": 1,     "ENABLE_PREFERENCES_SCREEN": 1,     "JWT_KEY": "xx",     "JWT_EXPIRES_IN": "30d",     "DEFAULT_USER_PAGE": "frontpage",     "NODE_ENV": "production",     "CONNECTION_TYPE": "mssql",     "DB_USER": "user",     "DB_PASS": "password",     "DB_NAME": "url_logger",     "DB_HOST": "localhost",     "DB_PORT": "1433",     "DB_INSTANCE": "SQLEXPRESS",     "ENABLE_LOGGING": 1,     "SQL_LOGGING": 0,     "USE_CLUSTER": 0,     "USE_SSL": 0,     "TOOLBAR_CLASS": "navbar border card-header rounded bg-light",     "SMTP_USE_TLS": 0,     "SMTP_HOST": "",     "SMTP_PORT": "",     "SMTP_USER": "",     "SMTP_PASS": "",     "ADMIN_EMAIL": "",     "SMTP_FROM": "" }
URL Logger logs gives me unable to connect
pp is listening at http://:::3333 2024-03-03 02:22:22.627 error:  uncaughtException: Failed to connect to localhost\SQLEXPRESS in 15000ms ConnectionError: Failed to connect to localhost\SQLEXPRESS in 15000ms     at C:\snapshot\url_logger\node_modules\mssql\lib\tedious\connection-pool.js:85:17
2 years 6 months ago #23328 by admin
Replied by admin on topic URL Logger on SQL Express
Have you enabled remote connections?
Is SQL server browser service running?
2 years 6 months ago #23329 by admin
Also is TCP/P enabled?
2 years 6 months ago - 2 years 6 months ago #23330 by prashant
Replied by prashant on topic URL Logger on SQL Express
SIGH , this was off , now login works !!
Thank you so much
Last edit: 2 years 6 months ago by prashant.
