URL Logger how to trigger ETL
2 years 5 months ago #23122 by prashant
I'm having trouble understanding how to trigger an ETL transformation once URL Logger receives a request and posts it in default SQLite or my chosen SQL database. Could you please advise on the process for initiating the ETL transformation after receiving the request?
2 years 5 months ago #23129 by Peter.Jonson
It was not designed for that.
Please use AETL scheduler to process web hook data.
2 years 5 months ago #23131 by prashant
Thank you
2 years 5 months ago #23134 by prashant
A followup question , what exactly is URL logger supposed to do ? I understand it allows for all webhook and JSON body to go into a structured db.
Then it's always through ETL scheduler ?
If I do want it quickly , then I can technically do a "trigger" in sql which runs ETL from command line? Any issues with this approach ?
2 years 5 months ago - 2 years 5 months ago #23135 by admin
Replied by admin on topic URL Logger how to trigger ETL
Correct, all it does writes webhook data into the database.
Having thought about it, we cad add the ability to execute code after after webhook data is recieved.
That is not that dificult to implemenet and will benefit a lot of users,
ETL takes time to start so if you have a lot of requests it might stall
Do you know how many requests you might get?
Last edit: 2 years 5 months ago by admin.
2 years 5 months ago #23138 by prashant
I am sure it will benefit others as well.
My requests are sporadic . 30-40 in whole day maximum but frequency can change. At upper end I am looking at 4-5 in a minute sometimes.
If the requests are queued and are processed 1 by 1 sequentially , I think it's good payoff instead of doing it parallely
