Python Calculation SyntaxError: "unterminated string literal" when using [F001]
7 months 3 weeks ago - 7 months 3 weeks ago #25899 by Onkar2002
Hi,
I am trying to use a Python script in the "Calculation" transformation to remove duplicates from a column.
The Issue: When I hardcode the data into the script for testing, it works perfectly. However, when I replace the hardcoded data with the input variable [F001],
I get the following error:
SyntaxError: unterminated string literal (detected at line 1)
my script
: raw_value  = str([F001]) items = [x.strip() for x in raw_value.split(',') if x.strip()] unique_items = for item in items:     if item not in unique_items:         unique_items.append(item) unique_items.sort() Result.value = ','.join(unique_items)
When I manually type the string (e.g., raw_value = 32607,32607), it works fine.
When I use [F001], it fails immediately.
In the "Data Preview" or execution log, the result for this column comes back as NULL because the script is failing.
It seems like the data inside [F001] might contain characters (like newlines) that are breaking the Python string syntax during the substitution.
Could you advise on the correct way to handle [F001] variables in Python that might contain special characters or newlines?
Last edit: 7 months 3 weeks ago by Onkar2002.
7 months 3 weeks ago #25900 by admin
Hi Onkar
1  When I use [F001], it fails immediately.
Parameters tab has a Test Value which you can use for testing and development
2 It seems like the data inside [F001] might contain characters (like newlines) that are breaking the Python string syntax during the substitution.
When [F001] is equal tp 1,2,3 the actual code executed is
raw_value  = str('1,2,3')
if [F001] has special characters the code will fail
This is expected python behavior, so what you need to do is to escape [F001] value
This can be done by using the following transformation
www.etl-tools.com/wiki/advanced-etl-proc...rings/escape-string/
Please keep us posted on your progress
The following user(s) said Thank You: Onkar2002
7 months 3 weeks ago #25901 by prashant
Taking Mike's hunch , I asked Chatgpt & it gave me a single line to remove the delimiter,
raw_value = raw_value.replace('\r', '').replace('\n', '')
I tried a simple test and it worked at my end & it worked fine.
The following user(s) said Thank You: admin, Peter.Jonson, Onkar2002
