Help me craft a SQL chatgpt prompt for AETL
11 months 1 week ago - 11 months 1 week ago #25766 by prashant
Hellos,
As I move slowly away from CSV to MS-SQL 2022, I would like to create a CHATGPT prompt similar to my python one to craft better queries .
What are some of the peculiar things to remember
Few Questions
1. Set NOCOUNT ON should be default when using transformations to update
2. When updating via Transformations , a single user query is preferred instead of separate ones for insert/udpate
insert into [items].[basecamp].[checklist_tasks] ("MasterTaskID","hr1_code","DueDate","bc_userid" ) values (?,?,?,?  )
update [items].[basecamp].[checklist_tasks] SET "hr1_code"=?,"bc_userid"=?  Where "MasterTaskID"=? AND "DueDate"=?
TO below(where custom logic is being used)
MERGE [items].[basecamp].[checklist_tasks] AS target
USING (
    VALUES (?, ?, ?, ?)
) AS source (MasterTaskID, hr1_code, DueDate, BC_UserID)
ON target.MasterTaskID = source.MasterTaskID
   AND target.DueDate = source.DueDate
WHEN MATCHED
    AND target.Status = 'Not Started'
    AND (
        ISNULL(target.hr1_code, '') <> ISNULL(source.hr1_code, '')
        OR ISNULL(target.BC_UserID, -1) <> ISNULL(source.BC_UserID, -1)
THEN
    UPDATE SET
        hr1_code = source.hr1_code,
        BC_UserID = source.BC_UserID,
        Status = 'Not Started',
        DateModified = GETDATE()
WHEN NOT MATCHED THEN
    INSERT (MasterTaskID, hr1_code, DueDate, Status, DateCreated, BC_UserID)
    VALUES (source.MasterTaskID, source.hr1_code, source.DueDate, 'Not Started', GETDATE(), source.BC_UserID);
n00b question
Is there a specific lingo preferred when updating ? source.MasterTaskID is how values are identified or we prefer ? ? approach all the time
Last edit: 11 months 1 week ago by prashant.
11 months 1 week ago #25767 by Peter.Jonson
A very important point is missing.
Into which object do you insert your SQL?
Screenshot?
11 months 1 week ago #25768 by prashant
SQL 2022 using transformation ?
different prompt for different places ? like Calculations script vs packages script
11 months 1 week ago #25770 by Peter.Jonson
1 You can insert it there Use User Defined SQL
www.etl-tools.com/wiki/advanced-etl-proc...pdatedelete-records/
or there sql script
2 www.etl-tools.com/wiki/advanced-etl-proc...s/sql-script-action/
For the first one you must use "?" (it is odbc style syntax)
For the second one it depends on the data base you are working with
11 months 1 week ago #25798 by prashant
Hellos,
I am out for 9 days for an intense meditation camp. Will explore this prompt once back :)
