[How to] Reduce PDF quality when running as package
1 year 9 months ago - 1 year 9 months ago #24638 by prashant
Hellos,
When running report manually I am able to access menu below and set the quality of PDF I want AND images inside PDF ,  I have selected JPEG as 80 selected below
How do I achieve the same using packages ? Do I need to use some variable ?
Last edit: 1 year 9 months ago by prashant.
1 year 9 months ago #24639 by Peter.Jonson
Although what you are asking us is not currently supported it is rather easy to implement.
We will add it for you to the next release.
The following user(s) said Thank You: prashant
1 year 9 months ago #24640 by prashant
Thanks , this will be useful ! Reports sizes due to images are getting crazy
1 year 9 months ago - 1 year 9 months ago #24641 by Peter.Jonson
FYI: Your suggestion was implemented in the latest release
 + Added: Support for Dynamic Package Actions to Search Parameters Dialogue
 + Added: Support for Dynamic Package Actions to Replace Wizard Dialogue
 + Added: Support for Dynamic Package Actions to Find String Dialogue
 + Added: Support for Dynamic Package Actions to Used By Dialogue
 + Added: JPEG Quality option to Report Dynamic Package Action
Last edit: 1 year 9 months ago by Peter.Jonson.
1 year 9 months ago #24642 by prashant
Thank you . Using 75% JPG reduced my file from 10MB to 5MB.
