[Showcase] Using Variables in Transformations - Validator and Transformation
2 years 1 month ago #24291 by prashant
HI,
I made a small project with using variables in Transformations. SEE LOOM
Features
1. Reads a CSV file
2. Uses loop to process them 1 by 1
3. Downloads each file using HTTP Get action
4. Uploads the file to Gdrive, outputs the Gdrive ID
5. Runs the transformation which uses validator to 'find' unique id , updates the gdrive value in csv
6. Update the CSV files
Overall fun little project
1. Question, if a file cannot be downloaded or if a file cannot be uploaded to gdrive, what's the best way to write this to another log or text file , using package - script or using transformation ?
2 years 1 month ago #24292 by prashant
Another question , if I wish to create an empty text file (csv) but only with headers, is script the only way ?
2 years 1 month ago #24295 by admin
Please use package - script action
2 years 1 month ago #24296 by prashant
Here's the python script , where I have hardcoded the location of the file with the headers I needed , this can be easily modified for others.
import etltools import csv import os csv_file_path = r'C:\Users\Superadmin\Documents\KBIAutomation\asp_upload\gdrive_asp.csv' headers = ['#rid#', '#qb_url#', '#filename#', '#gdrive#'] # Main function to create CSV with headers and a new line for appending data def main():     error_message = ""  # Initialize error message     try:         # Create or overwrite the CSV file and write the headers         with open(csv_file_path, 'w', newline='', encoding='utf-8') as outfile:             # Ensure all fields are enclosed in double quotes             writer = csv.writer(outfile, quoting=csv.QUOTE_ALL)             writer.writerow(headers)  # Write the headers            # Set result value to indicate success         Result.Value = 1     except Exception as e:         # Append all errors to error_message and set in ETL tools         error_message += str(e)         etltools.SetVariable('error_message', error_message)         Result.Value = 0 # Execute main function main()
2 years 1 month ago #24308 by Peter.Jonson
Here is much shorter version using Pascal Script
var FileName,Header: String;
begin
 FileName := 'C:\Support\gdrive_asp.csv';
 Header := '"#rid#","#qb_url#","#filename#","#gdrive#"';
 StringToFile(FileName,Header);
 Result:=true;
end;
The following user(s) said Thank You: prashant
2 years 1 month ago - 2 years 1 month ago #24312 by prashant
Being jealous of pascal , I asked chatgpt to come up with a shorter script too
import etltools,csv csv_file_path = r'C:\Users\Superadmin\Documents\KBIAutomation\asp_upload\gdrive_asp.csv' headers = ['#rid#', '#qb_url#', '#filename#', '#gdrive#'] with open(csv_file_path, 'w', newline='', encoding='utf-8') as outfile:     writer = csv.writer(outfile, quoting=csv.QUOTE_ALL)     writer.writerow(headers) Result.Value = 1
Last edit: 2 years 1 month ago by prashant.
