Micro Guide to Calculations with Python + Chatgpt
1 year 11 months ago - 1 year 11 months ago #24101 by prashant
Hellos newbie,
I am fellow newbie,The stance of ETL-tools team is simply calculations are slow and should be avoided. I totally agree .
BUT If you still want to use calculations using python, here are some guidelines for chatGPT which you can copy paste before asking it what to do
Here's a summarized guideline for writing and running Python scripts in the described style, specifically tailored for use within ETL-Tools calculations:
COPY PASTE FROM HERE
I want to make python script but I want you to follow these guidelines.Yes, I understand. Here's your input formatted and ready to be used. If you understand them give me yes/no , so I can proceed
Guidelines for Immediate Execution Python Scripts in ETL-tools using Caluclations
  • Immediate Execution The script is executed from top to bottom without needing any special entry point like `main()`.
  • Output Specification The result must always be assigned to `Result.value`. This is case-sensitive; using `result.value` will not work.Always assign the final result to `Result.value`.
  • No Printing The output should not be printed; it must be assigned to `Result.value`.
Handling Input Variables
  • String Inputs All input variables passed into the script are strings by default.
  • Be Default , ETL-Tools passes variables into Python using `[F001]`, `[F002]`, `[F003]`, etc. These variables can be referred to directly in the calculations. As given above they will always be string
  • Conversions Convert input strings to the required types (e.g., integer, array) within the script.
Important Notes
  • Result Initialization : There is no need to initialize the
    Result
    class within the script.
    Result.value
    is always initialized by ETL-Tools.
  • Direct Variable Reference: You can directly refer to ETL-Tools variables and perform necessary calculations without intermediate assignments.
Example
In this simple example , we want to add 200 to our value . Default variables are with [F001] , you assign it a number , 54 in our case
Result.value=int([F001])+200
In Editor window , notice we convert F001 back to integer . Press Run Button
Congrats you've run your first script.
Last edit: 1 year 11 months ago by prashant.
The following user(s) said Thank You: admin, Peter.Jonson
1 year 11 months ago #24129 by admin
FYI: We have updated wiki based on the information you provided
www.etl-tools.com/wiki/knowledgebase/tips/working-with-python/
1 year 11 months ago #24130 by prashant
Wohoo !! Hoping it becomes easier for new users to try ETL-tools
