Still need help with pivots - Single Column Pivot
1 year 11 months ago - 1 year 11 months ago #24095 by prashant
sigh !
I think I need an intervention when it comes to pivot and unpivot
Let's start with pivot, I understand it can do some incredible grouping , but I can't even wrap my head around single pivot
Excel Terms
I want to pivot on Field Status, So Column Becomes Status , Rows = Brands , and Record id# is the value I want to "COUNT"
EDT Terms
Set Key ?; Pivot Key = Status  ; Pivoted Value= ?
What does Pivot Keys do here?
Input
Output
Expected Output from  Entire Dataset
File Attachment:
File Name: output.xls
File Size:7 KB
File Attachment:
File Name: input.xls
File Size:17 KB
Last edit: 1 year 11 months ago by prashant.
1 year 11 months ago #24102 by Peter.Jonson
You need to sort and group the data first.
I will create an example for you
The following user(s) said Thank You: prashant
1 year 11 months ago - 1 year 11 months ago #24103 by Peter.Jonson
Please see attached working example.
Last edit: 1 year 11 months ago by Peter.Jonson.
1 year 11 months ago #24107 by prashant
HI,
Thanks for the example .it's clear(ish) now. Let me try
0. Sorting is critical
1. Pivot by itself will not do any calculations (sum/count)
2. To do this grouper is required where we employ Group by fields and actually do calculations we want
3. IN pivot , PivotKey is where we list down ALL the columns we want, if a pivot key is NOT listed that "value" will not be a part of output
4. In example provided , I could have , not removed Record ID# using field selector , and instead used counting in Record ID#??
I am going to do a video on this, this would be helpful for me in future to remember , or for someone in my team as well
Now this is the easy Single Column Pivot  .
The wiki talks about a slightly complex pivot , can I get the example file for that (if you have)
1 year 11 months ago #24113 by Peter.Jonson
>>>I think this will work as well, as you can see there are multiple ways of doing things with our software
>>. Yes we do have it in default repository 0037 Pivot Example.
PS you are not the only one who is confused about the pivot (I keep forgetting how it works)
1 year 11 months ago #24116 by prashant
Video as promised for Future Self
www.loom.com/share/4bbb2898938740eabd256...6b-8a62-2ee63c3eacc5
Do you know there is an upper limit to characters in Pivot Key for some reason ? Please remove , makes user job difficult  . See video at 4:24 to know what I am talking about
