[Guide] Using ETL-Tools Packages for Workflow Orchestration for Python packages
2 years 3 months ago #23979 by prashant
Warning
I am not a programmer ,if you don't' agree I apologise , code all the way
One non advertised usage of ETL-Tools is to use it for flow orchestration between python scripts , Yes you heard me right , the space occupied by Airflow or Prefect Server.
Allow me to demonstrate with a photo first and then my observations
  • Step 5 & Step 6 are both Python script ,Input of 6 comes from 5
  • Like Prefect Server or Airflow ,it's very easy to see from the logs where the mistakes are coming from
  • You get tonnes of Options , whether script should run async or parallel , either by waiting for script to finish or not
  • Options 1/2/3 provide you to run scripts with all your command line options
My take
  • It's easy to get chatGPT to write small script and maintain it, the moment script becomes complicated it starts becoming difficult to troubleshoot .
  • Using above approach , with modular scripts , you can ensure that it's easy to troubleshoot
  • We've slowly moved many things out of Python and moved them to ETL-Tools like mailing with postmark
  • It's a wonderful marriage of low code+ no code
2 years 3 months ago #23980 by admin
Looks very nice and useful
2 years 3 months ago #23981 by prashant
You have no idea , for ChatGPT programmers such as myself , this is so easy to manage flow between scripts without learning anything new !
