Correct Procedure for In Place Upgrade of SQL Repository
2 years 4 months ago #23289 by sampelje
Hi,
I have had this happen a few times now.  I attempted an In-App upgrade of Advanced Processor Enterprise with an MS SQL repository and apparently, the new code requires a schema update but does not update the SQL repository.
In this case, I attempted to move from 6.3.10.10 to 6.4.2.3.
What are the correct steps to successfully update the code and have it update the MS-SQL repository correctly?
Thank you.
2 years 4 months ago #23290 by Peter.Jonson
We always publish repository upgrade scrips here
www.etl-tools.com/repository-database-updates/
Looks like you have run scrips starting from 006
Please make sql server backup first
2 years 4 months ago #23295 by prashant
Just asking as a non sql admin
1. We backup the sql
2. Run above scripts from command line (mySQL in my case)
3. Enjoy benefits ?
Any steps missing?
2 years 4 months ago #23297 by admin
If you running the latest version there is no need to run the scripts.
All you need to do is to "enjoy the benefits"
The following user(s) said Thank You: prashant
