Scheduler Package Not Running
3 years 1 month ago #22588 by Tafadzwa
Hi,
I have a pipeline that is called Mapp. When I push it manually it works but when i create a package and add it to the execution log i get the error attached. The scheduler time to run the pipeline is working well but the push is giving me errors. Can you please explain how to fix that issue. Please dont send me the links to read because i have already done that and i am failing to fix the issue
3 years 1 month ago - 3 years 1 month ago #22589 by admin
Replied by admin on topic Scheduler Package Not Running
If you click on the first line you will see a different log. It might tell you what is the problem. It might fail because your file is on mapped drive. Mapped drives do not exist inside windows services. Please use unc path instead. If it does not help please post another log file as text
Last edit: 3 years 1 month ago by admin.
